串口通信
回帖:0个,阅读:11538次 [上一页] [1] [下一页]
29793
思南 管理员
文章数:14043
年度积分:65
历史总积分:29793
发表于:2001/8/18 7:44:00
只用了tapiRequestMakeCall函数的简单程序,可以了解一下TAPI与直接用AT指令控制MODEM的区别。建立窗口,放置Command1,直接将代码粘贴到窗口CODE中就可以了。
Option Explicit
     Private Declare Function tapiRequestMakeCall Lib "tapi32.dll" _
        (ByVal stNumber As String, ByVal stDummy1 As String, _
        ByVal stDummy2 As String, ByVal stDummy3 As String) As Long
     Private Const ID_CANCEL = 2
     Private Const MB_OKCANCEL = 1
     Private Const MB_ICONSTOP = 16, MB_ICONINFORMATION = 64
     Function DialNumber(PhoneNumber)
        Dim Msg As String, MsgBoxType As Integer, MsgBoxTitle As String
        Dim RetVal As Long
        ' Ask the user to pick up the phone.
        Msg = "Please pickup the phone and click OK to dial " _
           & PhoneNumber
        MsgBoxType = MB_ICONINFORMATION + MB_OKCANCEL
        MsgBoxTitle = "Dial Number"
        If MsgBox(Msg, MsgBoxType, MsgBoxTitle) = ID_CANCEL Then
           Exit Function
        End If
        ' Send the telephone number to the modem.
        RetVal = tapiRequestMakeCall(PhoneNumber, "", "", "")
        If RetVal < 0 Then
           Msg = "Unable to dial number " & PhoneNumber
           GoTo Err_DialNumber
        End If
        Exit Function
Err_DialNumber:            'This is not an On Error routine.
        Msg = Msg & vbCr & vbCr & _
           "Make sure no other devices are using the Com port"
        MsgBoxType = MB_ICONSTOP
        MsgBoxTitle = "Dial Number Error"
        MsgBox Msg, MsgBoxType, MsgBoxTitle
     End Function
Private Sub Command1_Click()
Call DialNumber("0755")
End Sub
4694.6352
