工控英语角
回帖:1072个,阅读:231300次 [上一页] [1] [2] [3] [4] [5] [6] [7] [8] [9] ... [108] [下一页]
1878
清影
文章数:400
历史总积分:1878
2014逛工博
发表于:2004/7/6 14:41:00
(1) 元件设备
三绕组变压器:three-column transformer ThrClnTrans
双绕组变压器:double-column transformer DblClmnTrans
电容器:Capacitor
并联电容器:shunt capacitor
电抗器:Reactor
母线:Busbar
输电线:TransmissionLine
发电厂:power plant
断路器:Breaker
刀闸(隔离开关):Isolator
分接头:tap
电动机:motor
(2) 状态参数
有功:active power
无功:reactive power
电流:current
容量:capacity
电压:voltage
档位:tap position
有功损耗:reactive loss
无功损耗:active loss
功率因数:power-factor
功率:power
功角:power-angle
电压等级:voltage grade
空载损耗:no-load loss
铁损:iron loss
铜损:copper loss
空载电流:no-load current
阻抗:impedance
正序阻抗:positive sequence impedance
负序阻抗:negative sequence impedance
零序阻抗:zero sequence impedance
电阻:resistor
电抗:reactance
电导:conductance
电纳:susceptance
无功负载:reactive load 或者QLoad
有功负载: active load PLoad
遥测:YC(telemetering)
遥信:YX
励磁电流(转子电流):magnetizing current
定子:stator
功角:power-angle
上限:upper limit
下限:lower limit
并列的:apposable
高压: high voltage
低压:low voltage
中压:middle voltage
电力系统 power system
发电机 generator
励磁 excitation
励磁器 excitor
电压 voltage
电流 current
母线 bus
变压器 transformer
升压变压器 step-up transformer
高压侧 high side
输电系统 power transmission system
输电线 transmission line
固定串联电容补偿fixed series capacitor compensation
稳定 stability
电压稳定 voltage stability
功角稳定 angle stability
暂态稳定 transient stability
电厂 power plant
能量输送 power transfer
交流 AC
装机容量 installed capacity
电网 power system
落点 drop point
开关站 switch station
双回同杆并架 double-circuit lines on the same tower
变电站 transformer substation
补偿度 degree of compensation
高抗 high voltage shunt reactor
无功补偿 reactive power compensation
故障 fault
调节 regulation
裕度 magin
三相故障 three phase fault
故障切除时间 fault clearing time
极限切除时间 critical clearing time
切机 generator triping
高顶值 high limited value
强行励磁 reinforced excitation
线路补偿器 LDC(line drop compensation)
机端 generator terminal
静态 static (state)
动态 dynamic (state)
单机无穷大系统 one machine - infinity bus system
机端电压控制 AVR
电抗 reactance
电阻 resistance
功角 power angle
有功(功率) active power
无功(功率) reactive power
功率因数 power factor
无功电流 reactive current
下降特性 droop characteristics
斜率 slope
额定 rating
变比 ratio
参考值 reference value
电压互感器 PT
分接头 tap
下降率 droop rate
仿真分析 simulation analysis
传递函数 transfer function
框图 block diagram
受端 receive-side
裕度 margin
同步 synchronization
失去同步 loss of synchronization
阻尼 damping
摇摆 swing
保护断路器 circuit breaker
电阻:resistance
电抗:reactance
阻抗:impedance
电导:conductance
电纳:susceptance
导纳:admittance
电感:inductance
电容: capacitance
大家看了也不支持我一下!
[此贴子已经被作者于2004-7-6 14:52:10编辑过]
清风无影
3439
emliy
文章数:1105
历史总积分:3439
发表于:2004/7/6 14:58:00
thanks!
1193
tangyong11
文章数:59
历史总积分:1193
发表于:2004/7/6 15:38:00
支持一下。
1059
diegozhaoxg
文章数:7
历史总积分:1059
发表于:2004/7/6 16:05:00
顶!
1393
chenqa11
文章数:213
历史总积分:1393
发表于:2004/7/6 21:21:00
不错
1017
qudong13
文章数:7
历史总积分:1017
发表于:2004/7/7 11:47:00
顶
1713
ljx9035616
文章数:463
历史总积分:1713
发表于:2004/7/7 13:35:00
电容写了两遍!呵呵,玩笑而已.
举起双手支持!
一个人在追求什么?不是真实就是幻想。
一个人在害怕什么?不是寒冷就是孤寂。
一个人在逃避什么?不是别人就是自己。
一个人在征服什么?不是世界就是心灵。
993
bgf
文章数:72
历史总积分:993
发表于:2004/7/8 0:03:00
8错8错
960
davidjiang
文章数:52
历史总积分:960
发表于:2004/7/8 8:58:00
ding!!
2149
godspeed 版主
文章数:428
历史总积分:2149
发表于:2004/7/8 12:20:00
挺好的,多谢先
我爱你
但我不会告诉你
我怕告诉你之后我会死掉
我不怕死
但我怕死后
没有人象我一样爱你!
1000.0961
