发表于:2006/2/2 19:51:00
[rm=300,30]http://grm.cdn.hinet.net/xuite/c5/d3/13989852/blog_144414/dv/4510412/4510412.mp3[/rm]
Borderline
So you''''re on your own lookin'''' down the road
that goes only by one way
And you don''''t need the signs to see lonely still runs both ways
So who''''s the fool that would think the ties
would be better off undone
Did your heart even warn you
when you veered from the path that was narrower and straight
On the borderline
Somewhere between the flight for freedom
Feeling like you can''''t move on
The chore will be the time
Takes you off of my mind and out of my heart I know
And when you cross over there''''s no turning back
Once that burning bridge is gone
I may lose but I''''m in it for the long run
Loving you for good reason could be the wrong one
I don''''t wanna lose control but the heart won''''t learn
To let it well enough for long
On the borderline
下载地址:http://grm.cdn.hinet.net/xuite/c5/d3/13989852/blog_144414/dv/4510412/4510412.mp3
Borderline
On the borderline
On the borderline
[此贴子已经被作者于2006-2-2 19:52:12编辑过]
