发表于:2011/7/26 10:35:47
Engineering 《工程》期刊导读
ISSN: 1947-3931 (Print) 1947-394X (Online).
《工程》ENG免费下载网址: http://www.scirp.org/journal/eng.
Table of Contents(Vol.03 No.06, Jun. 2011):
Uniaxial Modelling of Behavior of the Concrete in Fast Dynamics: Approach to Seismic Behavior
Abdelhak Baraka, Mohammed Benali Benmansour, Yazid Abdelaziz, Fakhreddine Djeddi
Reactivity of Fine Quartz in Presence of Silica Fume and Slag
Karima Arroudj, Abdelfetah Zenati, Mohamed Nadjib Oudjit, Abderrahim Bali et al.
Optimization of Permanent Magnet Skew in Permanent Magnet Linear Synchronous Motors Using Finite Element and Statistical Method
Gabriel González-Palomino, Javier Rivas-Conde, Edwin Laniado
Computation of Error in Estimation of Nonlinearity in ADC Using Histogram Technique
Radhe Shyam Gamad, Deepak Kumar Mishra
Improvement of Used Transformer Oils with Activated Bentonite
Loai Nasrat, Mohamed Abdelwahab, Gamal Ismail
The Effects of Dimension Ratio and Horizon Length in the Micropolar Peridynamic Model
Y. Ferhat, I. Ozkol
Slope Stability Analysis of Itakpe Iron Ore Mine, Itakpe, Nigeria
Rasheed A. Adebimpe, Jide Muili Akande, Chinwuba Arum
Machinability Study of Titanium (Grade-5) Alloy Using Design of Experiment Technique
Kali Dass, S. R Chauhan
Fibre-Reinforced Generalized Thermoelastic Medium under Hydrostatic Initial Stress
Praveen Ailawalia, Shilpy Budhiraja
Application of Hypothesis of Replacement at the Analysis of a Slow Flow of a Body by a Viscous Fluid
Andrey N. Volobuev, Eugene S. Petrov
Microscopic Observation of Nuclear Track Pores in Polymeric Membranes
Naveen K. Acharya
A Combined Probabilistic and Optimization Approach for Improved Chemical Mixing Systems Design
Matthew J. Opgenorth, William E. McDermott, Peter Laz, Corinne S. Lengsfeld
A Comparative Study on Several Anti-Corrosion Materials for Power FGD System
Zhenyu Wang, Dongsheng Mei, Weitao Zhang, Enhou Han et al.
Electrochemical Deposition and Optimization of Thermoelectric Nanostructured Bismuth Telluride Thick Films
Hesham M. A. Soliman, Abdel-Hady B. Kashyou
ENG是一本由科研出版社出版的关于工程领域最新进展的国际期刊。科研出版社(Scientific Research Publishing)作为开放读取(Open Access)的先行者、世界最大的开源期刊之一,目前已有180多种期刊及配套的电子版本,内容涵盖自然科学、农业科学、医药科学、工程与技术科学、社会科学等领域。多个期刊已被CAS,EBSCO,CAB Abstracts,ProQuest ,IndexCopernicus,Library of Congress,Gale, CSP等数据库全文或摘要收录。
期刊免费下载网址:http://www.scirp.org/journal/
EHQ2VP4
Y. Ferhat, I. Ozkol
Naveen K. Acharya
EHQ2VP4
[此贴子已经被作者于2011/7/26 10:42:32编辑过]
